A few days ago, ChargerLAB presented a compatibility 100 test video for the 16-inch MacBook Pro (2021) after upgrading it to macOS 13.5. Now, we will provide a detailed textual description, including more data, to give everyone a clearer understanding of the charging compatibility of this laptop.
For those unfamiliar with this laptop model, allow us to provide a brief overview. The 16-inch MacBook Pro (2021) is equipped with a 140W MagSafe charging port that supports the PD3.1 fast charging protocol. When combined with the authentic MagSafe charging cable, users can enjoy an optimal charging experience. Additionally, the side USB-C port also supports charging, albeit at a slightly lower power compared to the MagSafe cable. In this article, we delve into the compatibility of this laptop after an upgrade, with all tests conducted using the MagSafe charging cable.
Original Chargers
Let's begin by examining the performance of the original chargers. Summarized in the table, the test data reveals that with the exception of low-power chargers, all other chargers trigger a 20V PDO, while Apple's 140W charger impressively triggers a high voltage of 28V.
When we visualize the data in a bar graph, the Apple 140W charger emerges as the top performer, delivering a remarkable 132.72W, perfectly triggering the PD3.1 fast charging protocol. When utilized with the MagSafe charging cable, all tested chargers can fully reach their power limits, demonstrating exceptional performance. However, for optimal results, chargers with a capacity of 60W or higher are recommended to attain the best charging experience.
Apple 20W:https://amzn.to/2UWnBIs
Apple 30W:https://amzn.to/3feFR6N
Apple 35W Traditional:https://amzn.to/3OWZ2S4
Apple 35W Compact::https://amzn.to/3bkFfh3
Apple 61W:https://amzn.to/3NNwRr9
Apple 67W:https://amzn.to/304sKAF
Apple 96W:https://amzn.to/3hPxoHP
Apple 140W: https://amzn.to/3cLGuWX
Third-Party Chargers
Turning our attention to third-party chargers. Most of these chargers activate a 20V PDO, while the 140W charger triggers a 27V PDO.
Represented in a bar graph, chargers of varying power levels offer discernible charging tiers for the laptop. This indicates a strong level of compatibility. The MagSafe charging cable extracts the full potential of each charger; among the 69 third-party chargers tested, none exhibited incompatibility or inadequate charging power. The charging compatibility demonstrated is truly impressive.
SHARGE 140W:https://amzn.to/463K863
UGREEN 140W:https://amzn.to/3CIpj2u
AOHi 140W:https://amzn.to/3CjnLf7
Mcdodo 100W:https://amzn.to/44hiKzv
SHARGE 65W:https://amzn.to/3XqQpo5
SHARGE 100W:https://amzn.to/3zzCYrD
OnePlus 100W:https://amzn.to/42hoB7L
AOHi 100W:https://amzn.to/3q6i1Cp
UGREEN 65W:https://amzn.to/3Gf4soo
Baseus 65W:https://bit.ly/3WelOIQ
Anker 20W:https://amzn.to/3ziNxfw
Baseus 30W:https://amzn.to/372lV5W
UGREEN 30W:https://amzn.to/3qZ5v8v
Power Banks
Next, we evaluate the performance of power banks. As we analyze the test data, we find that power banks supporting the PD3.1 protocol consistently trigger a high voltage of 27V.
When visualized in a bar graph, three power banks stand out for achieving charging powers exceeding 133W. Remarkably, all ten tested power banks showed compatibility without any signs of incompatibility or underperformance. The power banks, whether high-capacity or low-capacity, uniformly achieve their maximum power limits.
Anker GaNPrime 140W (737):https://amzn.to/3wODIYv
ZMI No.20:https://amzn.to/3pQfBZ6
Power Stations
Finally, we assess the capabilities of portable power stations. Among the ten stations tested, all reliably triggered a 20V PDO with a current of 4.66A.
Visualizing this data in a bar graph reveals a slight variance in the charging power of the ten portable power stations, all surpassing 90W, and without any instances of incompatibility.
EcoFlow DELTA mini 1700W:https://amzn.to/43YhQIt
BULLBAT 1500W:https://amzn.to/3Jr7o3R
UGREEN 1200W:https://amzn.to/3r4X4IQ
Upon reviewing the comprehensive compatibility tests conducted, it is evident that the 16-inch MacBook Pro (2021) stands out. As one of the initial Apple laptops to incorporate PD3.1 technology, its compatibility ranks among the highest of the models tested by ChargerLAB. Even after the upgrade to macOS Ventura 13.5, its compatibility remains exceptional. It not only showcases strong compatibility with PD3.1 chargers but also delivers commendable performance with PD3.0, PD2.0, and other chargers. Coupled with the MagSafe charging cable, its capabilities are optimized, almost reaching the peak power limit of each charger. As we move forward, we eagerly anticipate further charging advancements from Apple.
Below is the compatibility 100 test report issued by ChargerLAB.
1. Apple 15-inch MacBook Air - ChargerLAB Compatibility 100
2. Charging Review of Apple MacBook Air 2022 With M2 Chip
3. Charging Review of New Apple 15-inch MacBook Air
