Home › News › What's New › 10000mAh Power Bank丨 MOMAX Released Upgraded Magnetic Wireless Battery Pack with Stand
Jeffrey
August 15, 2022
Recently, MOMAX released the upgraded Magnetic Wireless Battery Pack with Stand, a 10000mAh pocket-sized power bank that features MagSafe compatible with tempered glass design.
10000mAh Power Bank丨 MOMAX Released Upgraded Magnetic Wireless Battery Pack with Stand-Chargerlab
The new upgraded power bank adopts the same design as the previous lineup, with clear tempered glass and a premium metallic edge, allowing you to see the wireless charging module and various components directly through the glass.
It supports 15W (max.) wireless output for Qi-enabled devices.
It adopts the magnetic wireless charging module and will snap firmly to iPhone 12/13/14 series, providing magnetic wireless charging and USB-C charging for iPhone and beyond.
It comes with a versatile and stable foldable stand, which can attach your phone to it vertically or horizontally to get a more comfortable view when using it for chatting, video, or watching movies.
In addition to magnetic wireless charging, you can also use the fast charging cable to connect to the USB-C two-way fast charging port on the side to get up to 20W PD. The iPhone 13 can be charged 50% in half an hour, and the port also supports 18W fast self-charging.
Its battery capacity is doubled from 5000mAh to 10000mAh, but the size and weight are not increased much. The size is about 102 x 66 x 20.5mm (4.01 x 2.59 x 0.8 inches), and the weight is about 230g (8.11oz).
The upgraded MOMAX Magnetic Wireless Battery Pack with Stand, a 10000mAh pocket-sized power bank features MagSafe compatible with tempered glass design.
It adopts the same design as the previous lineup, with clear tempered glass and a premium metallic edge, allowing you to see the wireless charging module and various components directly through the glass.
It supports 15W (max.) wireless output for Qi-enabled devices and adopts the magnetic wireless charging module and will snap firmly to iPhone 12/13/14 series, providing magnetic wireless charging and USB-C charging for iPhone and beyond.
1. New MOMAX 100W 6-Port Wireless Desktop GaN Charger Supports Simultaneous Charging of 7 Devices
2. Review of MOMAX Airbox Charging Station(A Foldable Power Bank)
3. The New TEGIC Block 02 Power Bank with Amazing Colors And Designs
Fast charging Power Bank Wireless Charger
Teardown of Mercedes-Benz V-Class Original 36W Charger
Charging Compatibility Test of Anker 737 Charger (GaNPrime 120W)
Qi2-Certified Products Exceed 800 Models!
October 11, 2024
The Lightweight Marvel: OnePlus Open Unveiled
November 30, 2023
USB-C Cable Inside | Xiaomi Launched the 10000mAh Pocket Power Bank
May 28, 2023
Realme Released 67W GaN Dual-Port Charger
March 28, 2023
Jeffrey
