Goal Zero has added a new, compact model to its portable power station lineup, with the Yeti 200X promising a lot more juice than the typical external battery. Even though it’s capable of recharging your phone up to twenty times, the Yeti 200X is still about the same size as a six-pack of Coke.
The Yeti 200X has a 187 watt-hour lithium-ion battery, which the company says can power a light for to to 180 hours. Or, you could run a laptop for over four hours, a recharge a tablet six times, or run a TV for up to two hours.
Ports include two USB-A, each good for 2.4 amps, along with an 18W USB-C, and a 60W USB-C PD. The latter can be used as an input, too, for charging the Yeti 200X. There’s also a 12V car-style outlet, plus a 6mm and an AC outlet.
As with the larger Yeti models you can selectively turn on or off the groups of outlets: that means, for instance, you’re not wasting juice on the AC inverter if you don’t actively need it at the time. The AC outlet supports 120W output, with 200 watt surge.
A simple display shows the current battery level in percentage form. When it comes to charging up, you can plug in the included AC adapter or a USB-C power supply. Alternatively, the Yeti 200X can be charged from a 12V car outlet, or using a solar panel. Goal Zero says a full charge can be completed in as little as four hours with the supplied AC adapter; if you have a 45W USB-C charger that can be cut to just two hours.
With a Goal Zero Nomad 28 solar panel, meanwhile, you’re looking at an eleven hour recharge time; step up to a Goal Zero Boulder 50 and that drops to 6-8 hours, sunlight levels depending. Not the quickest, certainly, but entirely free since you’re using the sun. Unlike some of the larger Yeti models, you can’t use both solar and AC power to recharge at the same time.
Although there’s clearly less power than, say, the Yeti 1400, which has sufficient battery to keep a fridge running for multiple hours, the upside is portability. The Yeti 200X weighs five pounds and measures in at a compact 7.9 x 5.1 x 5.1 inches. Shelf life – the amount of time you can expect it to hold a charge when not plugged in – is 6-8 months, Goal Zero says.The Yeti 200X is available now, priced at $299.95. A Nomad 28 solar panel, meanwhile, is $249.95.
Specifications:
Charger Times
Maximum input: 2 hoursWall Charger: 4 hoursNomad 28 Plus: 11 hoursBoulder 50 Solar Panel: 6-8 hoursBoulder 100 Solar Panel: 3-4 hours
Ports
USB-A port (output): 5V, up to 2.4A (12W max), regulated
USB-C port (output): 5V, up to 3A (15W max), regulated
USB PD port (input/output): 5-20V, up to 3A (60W max), regulated
6mm port (output): 12V, up to 10A (120W max)
12V car port (output): 12V, up to 10A (120W max) regulated
AC Inverter (output, modified sine wave): 120VAC, 60hZ, 1A (120W, 200W surge)
Charging port (input,8mm): 13-22V, up to 10A (120W max), regulated
Battery Details
Cell Chemistry: Li-ion NMC
Peak Capacity: 187Wh (14.4V, up to 13Ah)
Lifecycles: 500 cycles to 80% (discharge rate: 1C, full charge/discharge, Temp 25C)
Shelf-life: Keep plugged in, or charge every 3-6 months
Management system: MPPT charge controller, low battery protection
General
Product SKU: 22070
Chainable: No
Weight: 5 lbs (2.27 kg)
Dimensions 7.9 x 5.1 x 5.1 in (20 x 13 x 13 cm)
Operating Usage Temp: 32-104F (0-40C)
Warranty: 12 Months
Via: Slashgear
Source: Goal Zero
All Comments (0)
